enable icmp redirects ipv6 fast-path
Description
When enabled, IPv6 packets forwarded by hardware (fast path) may trigger ICMP redirects.
Syntax Description
fast-path IPv6 packets forwarded by hardware may trigger ICMP redirects
Default
Disabled.
Usage Guidelines
Use this command to trigger ICMP redirects when IPv6 packets are forwarded by hardware (fast-path).
The enabled or disabled setting is displayed when using the command:
# show ipconfig ipv6
Route Sharing               : Disabled
ICMP Redirect for Fast Path : Enabled
Max Shared Gateways         : Current: 4   Configured: 4
Interface              IPv6 Prefix                                        Flags
v1                     2001::1/24                                    -EUf---R-
v1                     fe80::204:96ff:fe1e:ec00%v1/64                -EUfP--R-
Flags : D - Duplicate address detected on VLAN, T - Tentative address
E - Interface enabled, U - Interface up, f - IPv6 forwarding enabled,
i - Accept received router advertisements enabled,
R - Send redirects enabled, r - Accept redirects enabled
P - Prefix address
This command was first available in ExtremeXOS 15.2.
Platform Availability
